how to remove the frame of a graph
Let me ask you a hopefully very simple question: How is it possible to remove the standard frame of a (xy-, waveform, etc.) graph so that only the graph itself is visible?
Another question is: Is it possible to rotate a text field in LabView 5.1?
Many thanks for your help!
(4,245 Views)
Hello Damian.
Yes...it IS very simple. Simply grab the inside corner of the graph window and drag it out till it covers the frame. Lower right and upper left corners will do th trick!
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(4,245 Views)
Use the paint tool and color the frame transparent.
(4,245 Views)
yes, many thanks, another answer I got is in my opinion the better: colour the frame "Transparent". Many thanks anyway
(4,245 Views)
Thank you very much!
(4,245 Views)
