how to read screendump image from clipboard to a file
I am trying to build a program that runs minimized while other programs are being used at the same moment. At certain moments I want to make a screenshot and save that information to a image file on the harddisk.
I have now the "user32.dll" to work and generate a "printscreen" push button. Now I want to write the information on the clipboard to an image file.
How can I read the information on the clipboard and use it in a VI?
Thanks in advance.
Ferry
(3,438 Views)
Under the graphics and sounds pallette>>graphic formats  you will find functions to take and image in and then write it to a file.    Also you can check this link out
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CBB2A111EE034080020E74861
Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,432 Views)
If the screen you want to capture is a VI, you should use Invoke Node -> Get Panel Image, and Write BMP File.vi.
See attached VI.
If the screen isn't made in LabVIEW, and it's minimized, printscreen can't catch it.
To save the clipboard image to file, you can import the clipboard image into LabVIEW first
(use Image Toolbox: http://www.geocities.com/gzou999/imgtool.htm), and then Write BMP File.vi
George Zou
George Zou
(3,422 Views)
The "Import Bitmap.vi" would probably be a good option for me, but unfortunately I get an error message with my labview version, 7.1..
Is there anyway to update this vi?
(3,404 Views)
Import Bitmap demo for LV7.1 is available at:
George Zou
(3,384 Views)
thanks,
works really great!
(3,360 Views)
