how to read internal counter of cDAQ
Hi
I am using cDAQ -9178 with NI 9474 digital output module for generating the SPWM pusle whose pulse width varies from 10 to 390 microsecond. for generating 6 pwm w/f  I have used 1 counter to provide clock sourse to digital line, I am getting the output not is desired form, output which i am getting is pulses of  same duty cycle then after some time it changes the width of all pulses to different pulse widt, output i require is 1 pulse with some duty cycle for 400 microsecond(TON+TOFF), 2 pulse with different duty cycle again for 400 microsecond(TON+TOff) and so on.  the required output imamge is asSPWM
How I configure my cDAQ to achive this
(3,208 Views)
Did you get the desired output? Can you please share your vi with me?
(1,779 Views)
Hi rbasu34:
    Not yet. What do you mean by vi?😂
(1,769 Views)
@JJ_is_going_to_ask wrote:
Hi rbasu34:
You posted on the LabVIEW forum. The program routines you write in LabVIEW and store to disk are called VIs for Virtual Instruments.
As to your question about what you try to achieve, I only understand Bahnhof, meaning it is as clear as mud to me.
Rolf Kalbermatter  My Blog
(1,745 Views)
