how to read data from txt file respectively
I am triying to form an equation between two known points. I want to do this with the attached VI, the most critical point is that I will read the x1, y1, x2 and y2 coordinates from the same .txt file. They will be written in a .txt file and I will send them to the appropriate channel (x1, y1, x2 and y2) respectively. How can I get data in a rule from a .txt file?
Could anyone please help me with this issue,
Best regards.
Message 1 of 11
(3,887 Views)
You are almost there.  You just need to index your values out of the 2-D array and wire each one to the respective terminal.
Message 2 of 11
(3,886 Views)
I have indexed them but it gives another error that expects array indexing in the formula node.
Message 3 of 11
(3,871 Views)
You have indexed your 2-D array into 4 1-D arrays.  You need to send it 4 elements.  So you need to wire up another input to tell which row or column of the 2-D array contains your data.
Message 4 of 11
(3,867 Views)
enable indexing....rt click array node
Spoiler
Message 5 of 11
(3,866 Views)
Thank you very much,
It has worked when I have indexed them.
Message 6 of 11
(3,853 Views)
Now I have to send data to index array module, in this vi I have send constanat input but I want the formula node to process the data from the 1.txt file row by row so what kind of input should I send to the index array?
Waiting for your valuable helps.
Message 7 of 11
(3,829 Views)
Sorry I forgot the 1.txt
Message 8 of 11
(3,824 Views)
Because your file is fixed length, you should be using a For Loop instead of a While Loop.
Set up your Index Array to give you columns.  Then auto-index at the loop tunnels to go row by row (as Apok had mentioned).
Message 9 of 11
(3,820 Views)
Dear RavensFan,
Thank you very much for your helps, I am bit new to labview so I usually can not find the appropriate functions easily. And a new problem has rised in my application. I should write the A, B and C numbers in the respective series to the file 2.txt. I am able to write them in a straight forward case but I want to write the next triples (A B C) in the next row. Like this;
A1 B1 C1
A2 B2 C2
A3 B3 C3
So how can I put new line constant and space constant to my VI?
Waiting for your valuable helps,
Message 10 of 11
(3,793 Views)
