how to read and analyze spreadsheet data file
I want to read a spreadsheet data file having two columns in order to analyze the data using Labview program. I am not an expert although I know some of Labview programming.
(3,079 Views)
I attach a sample vi to illustrate one of the ways you can go about reading your spreadsheet. There are additional examples in this forum and LabVIEW help.
(3,079 Views)
Aderogba submitted a good program, but you should note that if you want to read a spreadsheet file you will need to know how the columns are delimitted. Aderogba's program assumes a Tab-delimitted spreadsheet file. Tab-delimitted is one of the most common methods, but if you are using Excel (for example) you must specifically save your spreadsheet as a Tab-Delimitted Text file before you can read it in from LabVIEW.
(3,079 Views)
logman,
you've given a really good insight on the issue of reading from spreadsheet.
this is what i'm trying to do (using excel):
assuming the following is a spreadsheet created using excel ...
Temp (deg F) | Pressure(sccm)| ...
230 | 356 |
1500 | 897 | ...
784 | 1000 | ...
987 | 2002 | ...
i want to be able to re
ad each column (for example) and pass on to another function to plot the temp values on a graph (as a example)
how do you save the file as a "Tab-Delimitted text file"? and how do i get it to read each column as "Temp" values or "Pressure" values?
thanks
-r
(3,079 Views)
