how to read an xml database using xsd file in labview
I have Labview 8.5. I have an xml file (Database) that contains data from sensors. The data doesnt conform to the LabView's xml schema we have our own schema for the data. is there a way to extract the  digitized waveform data from this xml file by using our own xsd file?
Regards
Shoaib
Message 1 of 8
(6,529 Views)
You may want to check into Easy XML:
http://www.jkisoft.com/easyxml/
Message 2 of 8
(6,523 Views)
There's also the free LabXML, but it's a bit old and not as, errr... "easy".
Message 3 of 8
(6,513 Views)
I got the JKI easyxml but I have a question. How do i convert the xsd file to Labview Data Type variant? is there an easy way? i am thinking that i will have to create a cluster that matches the xsd file and then the parser will be able to read the xml file and output the data in the same format.
I am very very new to XML so any help will be appreciated.
Shoaib
Message 4 of 8
(6,501 Views)
Hi Shoaib,
I replied to your post on the JKI Software forums.  Please post your XML file, there, and we'll try to help you out.
-Jim
Message 5 of 8
(6,483 Views)
I am attaching the xsd file here since I am not sure if by attaching the actual 3MB XML file i will be giving away any info that im not supposed to.Please rename the attachement to fmd.xsd
All i'm looking for is to somehow get the data defined by the following
  <xs:complexType name="T_sample">
  <xs:attribute name="num" type="xs:int" use="required" />
  <xs:attribute name="value" type="xs:int" use="required" />
  <xs:attribute name="value_mv" type="xs:float" use="required" />
  </xs:complexType>
Message 6 of 8
(6,478 Views)
Jim,
heres the file i tried to de-identify it as much as possible. I am interested in the raw data in the xml file. The incoming xml files may have data for multiple episodes like in this example xml.
Message 7 of 8
(6,443 Views)
Hi Shoaib,
I've responded to your question, here.
-Jim
Message 8 of 8
(6,416 Views)
