how to put a marker in labview data
i have a VI which gets real time data from a device.The data is recorded in an excel file in 3 column's.I need a marker to break the data into different sets & the marker should read o or 1 & the marker data should be stored in 4th column of the same data.The data & marker will be recorder simultaneously & the marker signal comes from a sub VI which has a 3V output pulse.Can anyone suggest me ways to get it done?
Thank you,
Labfreak
Labview 8.5 version.
(2,939 Views)
Hi labstar,
why can't you write your marker with the other data? Can you explain a bit more?
Mike
(2,929 Views)
hello mike,
i need the marker along with the same data so that i can separate the data depending on the marker.It gives me accurate results.Hope it answered your qs.Awaiting a reply,
Labstar
LV 8.5
(2,904 Views)
Allow me to rephrase to Mike's question.  What specifically is giving you problems?
An "Excel" file is stored in an XML based format (as of 2007).  I doubt you are doing that.  I suspect you are writing to a generic spreadsheet format which Excel can read.  If that is the case, simply append your 0 or 1 to the other 3 data values.  If this part is giving you the trouble, post your code or a screenshot.
SubVIs can have many outputs, but a voltage pulse is not one of them.  It could output the number 3 with units of volts, but I suspect you are controlling a board or similar device to output 3V and you'd like the value 0 or 1 depending on the output state.  Usually not hard to implement, but once again, code or a screenshot will be necessary.  If your subVI simply turns the voltage on or off and stops running, a simple comparison inside your acquisition loop is probably all that is necessary.  If it runs continuously in a parallel loop you have other options to share information.
(2,887 Views)
