how to programmatically share a local folder using labview using netapi32.dll
Hello everyone
I am trying to share a local folder programmatically using labview. From what i could make out after reading posts was that i need to use NetShareAdd function in netapi32.dll. But it has parameters which the call library function node configuration window does not have. Could someone give me heads up towards the right direction i should be looking into.
Thank you
P.S. i am using labview 2013 and Windows 7 for this.
Message 1 of 1
(2,671 Views)
