how to programmatically select items in a tree
I am looking to persist the tree selection in my application (save to a file on close, load from the file on open), but I cannot figure out how to programmatically select an item in a tree on load.  I would like to select the item as well as have it highlighted as is the usual behaviour if selecting via mouse.
I have tried writing to the "ActiveItemTag" property, but this does not work.  Any ideas?
(7,699 Views)
Accepted by topic author AK01
AK01,
Try the "Value" property.  The value of a tree control is the tag that is currently selected, so setting the Value to the appropriate tree tag will highlight that item.
Chris M
(7,692 Views)
Hai,
"Value" Property hightlights the tree item given as input.  It is a string data type and hence wire the element tag to highlight that element.  If the "selection mode" is set to "1 or more items" then wire a 1d string array to high light multiple items.
Hope it helps.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(7,668 Views)
Thanks, guys, that works perfectly 🙂
(7,633 Views)
