how to print right angle triangle with asterisk sign in labview?
hello friends i am a newbe 2 labview so my question is what is the code to print right angle triangle
like *****
(4,956 Views)
Hi jeshu,
There are many ways of doing this, from simply printing a string constant which contains the stars, to an array containing the same, to a decreasing count of asterix in a For Loop, to ...  well the list might go on..  😉
Before suggesting anything, can you describe what you are trying to achieve and how you imagined you would implement this?  That way, a better suggestion could be made.  Also define "print".  Do you mean print to screen in a string indicator or to send it to a printer?  Or to light up some LED or LCD display?
R
(4,950 Views)
Accepted by topic author jeshu
Ideas are always infinite, it seems... Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(4,935 Views)
Does that mean Partha's solution worked?
(4,928 Views)
Smiley Very Happy
(4,906 Views)
