how to present characters on express table?
Why are you concerned about a 3D array when you are discussing a table? A 3D array cannot be displayed in one. A 2D array is multi-dimensional and is the only way a table can be represented.
Message 11 of 15
(754 Views)
I think I understand little about using array. Can you give me an simple example to  build  a table with at least 3 columns, the last one present strings.
Message 12 of 15
(745 Views)
Oh, thanks. I ve just found an example  (building tables.vi). I ll try. However I wish if I could use building express table. Your answer is helpful. thanks
Message 13 of 15
(744 Views)
Avoid using Express VIs, they re just for the understanding purpose for the beginners.
They ll create more problems when you use them in your executables.
Once you open their FP, they re like normal VIs.
But, you can always use the lower level VIs instead of Express VIs to achieve the same purpose.
- Partha ( CLD until Oct 2027 🙂 )
Message 14 of 15
(742 Views)
I think I have learnt much in this forum. Now I can solve my problem,of course, not with express table vi. I use low level VIs,it is simple to get my purpose. Thanks for all your ideas..
Message 15 of 15
(737 Views)
