how to plot multiple dynamic data on xy graph with same x axis
I have two different dynamic data, which have to be plotted in single xy graph. I am using iteration number as the time axis. Pl see code attached below. Dynamic data are represented as two different random numbers.
Question: How to get data2 also in the same plot??
(4,321 Views)
Why are you even bothering with dynamic data and the express graph? Simply use the regular XY graph. As the context help shows, you bundle one y array with the x array, bundle the other y array with the same x array, then create an array from the outputs of both bundle functions.
p.s. It is silly to be using an XY graph in this situation. A normal graph would be better when you are incrementing the x axis by one. The whole point of an xy graph is having an x axis with unequal x increments.
(4,319 Views)
