el 01-30-2013 09:53 PM
I'am new to labview2011. I need to plot a XY graph where X componnets are motor counts and Y components are intensity from photodetector which is aquied using DAQ 6009. I 'am not able to plot motor count versus intensity it always comes intensity verses time. So please help me in this regard the code is attached
¡Resuelto! Ir a solución.
el 01-30-2013 10:53 PM
Hello perumpadapu,
In the attached image X axis is time stamp & y axis is parameter. Follow same order and instead of time give your data.
It should work, Let me know the result.
el 01-30-2013 11:48 PM
can you send it as a VI I'am not understandng your reply. My problem is that my DAQ 6009 givestime and intensity information, but the piezo will give only count information. I made array with time ad piezo counts using build array VI and gave the array to the XY graph. But then also its not working
el 01-30-2013 11:56 PM
Send me your data and i will make it plot to XY graph
el 01-31-2013 01:07 AM
Turn on context help (ctrl-h) and mouse-over the xy graph. It will show you the expected data format for the XY graph.
el 01-31-2013 01:15 AM
Ok give me some time.
el 01-31-2013 01:21 AM
Hi friend,
In the same VI, VISA & XY graph is not good idea, First you can store the data in string or array then you can plot the graph.
el 01-31-2013 01:32 AM
The data being plotted is from the express VI, not the VISA read.
The original poster should see: Help -> Find Examples -> XY Graph.vi
el 01-31-2013 02:31 AM
I know that graph will be plotted from the data being passed instead of VISA.
Here i am attaching VI..Just look at it..You will come to know how data is passed to XY graph.
Try to use same one.
Hope this work & help.
el 01-31-2013 03:06 AM
I had done this . But problem is that when i'am plotting the motor counts is not taken as X-axis. The graph is between intensity and time(X axis). How can I ovrecome this problem.
