how to pass a waveform x/y scale to anoter waveform?
 My Question is about X scal and Y scale. see attached .I want to pass a defined X, Y scale of a waveform to another waveform ( i donnot want auto scale) in the same vi. How to do that ? And if  the two waveforms are not in same vi, but one waveform in one vi, the other waveform in another VI . how to do that ?
Could you give me a Labview code diagram screen picture to show it since i am use LV7.1 version so may not open your higher version vi . thanks a lot.
(2,575 Views)
Expand the property node and add the Range property !
Define a global variable containing the scale informations. Write it in your "master" vi. Use it everywhere else.
Chilly Charly    (aka CC)
(2,566 Views)
Hi friends,
can you attach this vi ?
I have same problem .
Thanks.
(2,423 Views)
