how to output analog value to adam 4024
hi
I am using labview 8.5. I am using modbus communication.I want to send analog value to ADAM 4024 to display it on a meter.How should i give addresses? i am not able to understand how to configure ADAM card to give out ANALOG output ,have successfully tested digital o/p.Please help me...
 Thank you
GAK
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(5,026 Views)
Hi Gak,
There are couple of ways to communicate with ADAM 4024:
1. ADAM 4024 provides .NET class library in http://www.advantech.com.gr/Support/sr_detail-5032.asp.htm. You can install it and call .NET class library via LabVIEW. You can check https://www.ni.com/docs/en-US/bundle/labview/page/using-net-with-labview.html on how to call .NET in LabVIEW.
2. As discussed in http://www.advantech.com.gr/support/sr_detail-5035.asp.htm, ADAM-4000 series can communicate via ADAM OPC server. Therefore, you can use LabVIEW DSC module, https://www.ni.com/en-us/shop/product/labview-datalogging-and-supervisory-control-module.html, to communicate with ADAM-OPC Server to show data in LabVIEW.
3. If ADAM-4024 can communicate with Modbus like you mention, you can use Modbus LabVIEW Library from https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019 to communicate with Modbus device. However, you need to check with Advantech which address to acquire data.
Regards, Kate
(5,013 Views)
Thank you sir for your reply
I have used last option, i.e. downloading library of modbus.Actually i was facing addressing problem,but i have solved that problem successfully.
I ll get back to you if i have other problem.
Thank you again
GAK
Gaurav k
CLD Certified !!!!!
(5,009 Views)
hello sir,
Can you please tell me you are from which company? Do you have any openings in your company or any of those you know of ?
Waiting for your reply.
Thank you
Gaurav kulkarni(ga_k9@rediffmail.com)
Gaurav k
CLD Certified !!!!!
(5,006 Views)
HI Gak
Have gone through the data sheet of the adam daq 4024. if u have gone through the data sheet there u will find the column called type code. this type code is nothing but it will specify the particular channel and u can write the range code to that address. for reference u can see the pic below in the 1st write block u should specify the type code and in 2nd write block u need to specify the channel register address. in the 2nd write block u need to give the values that is No. of holding register values.
Thank you and regards
Krishna
Design Engineer
(2,630 Views)
