how to out data from one if-else (case) and in another if-else (case)
Hello friends
i am using one case if-else in my project and it run at some specific time,
now i want to take out is data and in it anothe case if-else and run at different time.
how can i do that
any help is appriciated
thanks
asif
(2,077 Views)
You will have to provide more details.
Right now all i can say is that to take values out of case structure, you just drag the wire to the edge of it and click on the edge.
(2,051 Views)
please see attached file.
(2,041 Views)
Do you mean something like this? You can add a new case for a different time.
Note that you only have a 1 second window to catch these events. If the CPU is busy doing other things you might miss them.
(2,034 Views)
Do what RamonG suggested for the clock.
I don't know why you have 1s delay in the case and 100ms outside, but i suspect you don't need the in-loop delay.
If you want to keep the data from when your case is "true" then wire a feedback node and have "false" case just be a wire.
EDIT:
Also add a proper control to you loop exit and don't use the Abort button to stop your VI.
(2,024 Views)
hi
1s delay is for to write data only one time, if i dont put delay, several time data is written in file.
(1,977 Views)
