how to obtain e number (labview)
Hi, I'm quite new in labview and I'm doing some personal projects and I would like to know which is the best way to calculate the e number depending on the presition desired, with this formula e = (1+1/n)^n,  and show result as it has been defined with precision.
Many thanks
(5,801 Views)
Have you looked in the maths palette? From here you can implement any mathematical expression/equation.
I suggest you take a look at some of the free LabVIEW tutorials.
You can change the displayed precision of the number by right clicking on the control/indicator, right clicking on it and selecting 'display format'.
(blog)
(5,798 Views)
Hi nayobi,
in addition to Sam's comment: there also is a "mathematics" function palette with a power function.
And you should also learn the basic about precision of float calculations. Wikipedia has articles on that topic…
(5,747 Views)
Thanks for both answers, I've tried with Formula Node and I added the code:
int i;
float e[10];
for (i=0;i<10;i++)
e[i]= ((1+1/n[i])**(n[i]));
with proper input/output, and it works!
Thank you,
Nayobi
(5,738 Views)
Hi Nayobi,
why don't you use "real" LabVIEW functions?
(5,721 Views)
