how to move multiple plot scrollbars with one scrollbar
Does anyone know if there is a property node available where I can use the x-axis scrollbar on one plot to control several x-axis scroll bars at once?  I have three plots and I want them all to scroll back when I drag the scrollbar on one... I've been going through the property nodes but can't find one to do this.
Much Thanks!
(3,012 Views)
Accepted by topic author Fibo
I think the only way to do this is to monitor the X scale's range, such as the range start. If the user clicks on the scrollbar the range changes so you can detect it that way. You can then set the scale range on the other graphs to match.
(2,980 Views)
