how to measure freq. using usb6008 daq?
hai,
i have to measure the frequency of the o/p pulse from the proximity sensor. which is the best method to measure the frequency. do u have any example code.
thank u.
(2,780 Views)
Hello visswa,
The only counter operation you can do with the USB-6008 is simple event counting. But, you can use that example, along with some software timing to calculate the frequency of your signal. Take a look at the example attached. It isn't as accurate as doing a hardware frequency measurement but with the USB-6008, it's probably your best option.
-Alan A.
(2,766 Views)
