how to make transparent vi except controls?
hi,
     i made a vi. that i want make a transparent in background and boolean control should be visible. just like if i drag from the control pellet from boolean.
how to do this
Balaji DP
(3,655 Views)
Hi balaji,
I don't think you can make vi transparent and keep control on it visible. It will have same transparency as Vi front panel.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,647 Views)
Balaji,
if your UI only contains a single control, you can manage to achieve something near your request.
Please note that from style guide, it is not suggested to create UIs in such a way. An application should have dedicated dialogs/interfaces and not a "random number of controls popping up from time to time somewhere on the screen".
Please see attached VI for a possible solution (observe the VI Settings >> Window Appearance for further hints).
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,629 Views)
                   you said right, i did the same for Graph thats looks good. actually i making a software which i can able to design my front panel where i can choose numeric, boolean, gauge, meter indicators and graph, also i can select the channel for each controls. i made a template of all the above controls and using vi server i can call the vi.
if possible to make a transparent back ground then my software looks very effective one.
Balaji DP
(3,622 Views)
