how to make the xy graph window appear flat instead of raised box
Hi All,
I need to save screen space by using a xy graph window that is flat instead of raised box alike. How do i do that in LabView 6.1, preferrablly manually and permanetly. Thanks for any help.
Bryan
(2,822 Views)
Just take it in the control editor (select, then "edit..customize control..." and color the raised box transparent. Now save he control under a new name and place it in your user palette for easy access.
(2,819 Views)
Hello Altenbach,
Thank you for the reply, it worked excellently!
Bryan
(2,811 Views)
