how to make text scroll in a chart/graph
I am trying to make a small example labview app.
I need to show a graph/chart with continuous data measurements, plotted over time. So far I have been using charts, since they suit my needs. I have seen though, that graphs are also a possibility. So if a solution calls for that, it might be ok.
Now I have two things that i dont know how to do. I have attached a picture of what i want to do.
I need to have time on the x axis, but i can only get it in the end points of the scale, can this be fixed (see the attached picture example)
I also need to mark phase starts endings. This means I need to have text scrolling along with the plot, keeping a white marker line at the starte point of the phase. Can thios be done somehow? I have already looked into Annotations, but I dont think thats it. (see the attached picture.)
If further explanation is needed, I would be happy to supply it.
Kind regards Daniel
(2,653 Views)
One option with graphs is to right click the graph when the code is running, select "Create Annotation". This will add a label to the graph that moves as the graph updates.
An alternative, and probably prettier approach, was discussed recently here;
http://forums.ni.com/t5/LabVIEW/Two-background-colors-for-the-same-waveform-graph/td-p/1139000
Hope that helps,
Ian
(2,631 Views)
