how to make it to move
hey
here is a example that can draw 2 circles and 1 oval. I want to know how to make the second circle round with the first circle aloong oval.
thank you
fay
(2,631 Views)
The blue circle should be drawn as last element, using a loop. You just need to calculate the postion of the center. Quite easy if you use polar coordinates, since an ellipse equation is simply
x = a sin Alpha + xoffset
y = b cos Alpha + yoffset
where a and b are the semi-axis of the ellipse.
I have modified your vi accordingly. There is still some tunning to be done on the x and y offset, since the ellipse is not centered on the central circle.
Chilly Charly    (aka CC)
(2,621 Views)
thank  you very much!
(2,606 Views)
