how to make a Multiplot of TDMS file
Hi
I get data created from a Vector Network analyser as TDMS file. now I need to plot these data to compare and show it in  a multiPlot  chart.
Regards
Message 1 of 15
(4,276 Views)
LV obviously incorporates a complete API for retrieving data from a TDMS file that is very easy to use (check the examples), however there is also a TDMS Viewer VI on the TDMS palette that you can also use to interactively explore data in a TDMS file. There is even a TDMS plugin for Excel.
What specifically are you wanting to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 15
(4,260 Views)
Thanks ,
I have looked into the example's and the discussion Forums ,but couldn't find what I am looking for .
here attached My Data and the Vi I created which could plot only one chart.
Message 3 of 15
(4,221 Views)
Hi ,,find attached
Message 4 of 15
(4,220 Views)
2 Strikes and still no attachments...
Mike...
LabVIEW Champion
Message 5 of 15
(4,207 Views)
Hello
 regarding the attached ,I tried twice but it did work and this the third time.....let's seeSmiley Sad
Message 6 of 15
(4,201 Views)
Try zipping up your code and post the zip file.  For some reason, Lithium doesn't like VI files coming from certain locations.
Message 7 of 15
(4,194 Views)
Message 8 of 15
(4,175 Views)
You only getting one plot because that is all you are asking for. You are extracting two waveforms from the file and using one for the X values of the XY graph and one for the Y values. What is it that you want?
Mike...
PS: hook up your error clusters
LabVIEW Champion
Message 9 of 15
(4,123 Views)
Thanks Mike.......I know what you mention but even if I put that in a while Loop ,I still have one Plot.
what I am asking for how to make Graph keeps all the plot together and how the program could  retrieves all  the channels automatically  .
Regards
Message 10 of 15
(4,116 Views)
