how to make 2 state machines run dependently ?
You just go to File >> Save For Previous Version... but I will see if I can make an example based on your picture.
Message 11 of 18
(1,405 Views)
oh, thanks, could you check this attachment again? This is 16 version now
Message 12 of 18
(1,401 Views)
Here is an example where I send a notification to the bottom loop every 5 seconds. When we want to exit, we send "False" instead of "True".
Message 13 of 18
(1,397 Views)
I am thinking this can be done in a single state machine and be a lot simpler. I might have to play with this a little when I am at my desk.
Message 14 of 18
(1,382 Views)
i thought of making an example with user event (queues), but for this example there is no need for it.
hope this helps
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 15 of 18
(1,362 Views)
thanks for your help!!! Thank you!!
Message 16 of 18
(1,334 Views)
I know we've started to move the discussion away from parallel loops, but one other option in 2016 and newer is Channel Wires.
Aside from that I'm also in the Queues or nothing camp.  Similar experience as others where I think this solution just needs a notifier, or occurrence, or rendezvous, and usually end up replacing it with a queue. (or channel)
Message 17 of 18
(1,304 Views)
Thank you sir, it's working now!
Message 18 of 18
(1,295 Views)
