how to link items in the PC, to the items added in the "edit items..." list of the combobox
Hello
Could someone please tell me how could I link the items added in the "combo box" could be linked to the files saved in my PC and if a new file is added to the same folder in my PC it could be added directly to the list of the combo box items.....Thanking you in advance
Regards
Pratheek
Message 1 of 8
(3,418 Views)
Just do a Recursive File List and then put the results in the Strings[] propery (use a property node) of the combo box.
Message 2 of 8
(3,397 Views)
Thanks alot 🙂
Message 3 of 8
(3,391 Views)
if you dnt mind could you please attach the VI....... its not working in my case
Message 4 of 8
(3,378 Views)
Save that image I gave you earlier to your desktop.  Now drag the image file on your machine onto a blank VI.  You will automagically have the code.  It is called a snippet.  I saved that snippet with LabVIEW 2013, so you will need at least 2013 for it to work.
Message 5 of 8
(3,359 Views)
but I am using Labview 2010 😞
Message 6 of 8
(3,354 Views)
Here you go then.  I saved it in 2010 for you.
Message 7 of 8
(3,349 Views)
Accepted by topic author pratheek
Thanks alot .........
Message 8 of 8
(3,346 Views)
