how to insert image in IMAQ Browser insert
 hi,
      how to insert multiple image in IMAQ Browser insert vi. will taken image from folder.
Message 1 of 12
(8,725 Views)
-You need to first setup the Browser http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_browser_setup/ with multiple images per line.
-You have two modes to insert the image to browser either the last position or the first vacant position, depending on the selected mode.
-You can use for loop and insert one by one.
Edit: Check the Browser example-> Help->Find Examples->Search for browser.
uday
Message 2 of 12
(8,708 Views)
hi ,
           i try this but get error for IMAQ image focus vi.
Message 3 of 12
(8,697 Views)
hi,
       thi is i try vi.
Message 4 of 12
(8,694 Views)
Hope uday has given enough information on insert image.
If you are getting error still you can share the code which you tried so that we can debugg and tell you the problem.
Message 5 of 12
(8,691 Views)
Find the attached code
use separate event for Stop and stop the loop.
Message 6 of 12
(8,674 Views)
Modified for better readability
Message 7 of 12
(8,669 Views)
there is example code for this question inside labview example
check that example
the name is
Browser Example.vi
Message 8 of 12
(8,667 Views)
What error you got?
-What is the use of Case structure if False Constant is connected? (it will run only False case and what is the use)
-What is the use of IMAQ dispose before IMAQ create?
-IMAQ Browser Setup VI accepts RGB(U32) image type and you connected IMAQ create and left the image type unconnected(What is the default type IMAQ Create uses?)
-Why do you need property node instead you can directly send to Image Browser indicator right?
-Where is Stop event? Why is it infinite loop? Are you trying to use Abort to stop?(If it is strictly it is not the way how you should be stopping)
-Did you check the example post i told you to check in my previous post?
uday
Message 9 of 12
(8,665 Views)
hello uday,
thanks for echoing all my questionsSmiley Happy
Message 10 of 12
(8,663 Views)
