how to insert data from file into matlab script node
I have interfaced input data from file to be processed using matlab script node. But the problem is that I could not capture the multiple data into matlab script node and to convert it into matrix. Further to this I need to process the data by plotting graphs from it. Thank you in advance for the advice
(3,220 Views)
Zarina,
To clarify your problem, you have a script node contaning your Matlab code. Are you then using the standard LV functions to load in your data from a file and pass it into the script node?
Regards
Tristan
(3,220 Views)
