06-24-2018 07:18 PM
Hi guys,
so in my software (2014_Conex working version) a small delay stage is controlled by an external Conex CC controller box (both Newport). At the moment, the delay stage moves in a specific range and steps at specified number of positions. I'd like to add a Newport Power Meter (PM, 841-PE-USB;) in such way, that it measures the power at a specific position and then plots both, where the position of the delay stage is x-axis and the power is the y-axis. I was told to save the PM code as a SubVI since it's fairly small and just insert it into the main and larger code. I'm not sure, where and how to connect the SubVI and I was hoping you could help me? I'd really appreciate your help, since I'm new to LabVIEW.
06-24-2018 09:17 PM
Some very quick comments:
06-24-2018 09:32 PM
thank you for the suggestions. Here's the full code for the PW:
