how to insert 1D array to mysql database
HI all,
I have 1D array like in the attached file, after inserted this array to mysql database and I want to read it again.It looks like in the photo q2!! I was wandering if there is someone can help me to read it again as I inserted (1D array) and not like a one cell. Thanks in advance
Regards
(4,337 Views)
You insert not array of numbers or strings, but single string.
First of all you need understand what you want: string, array of string or array of dbl.
(4,304 Views)
Hi artem,
Actually , I want to insert array of dbl and read it again as it is.. how can I do that? thanks in advance
(4,294 Views)
You need to insert the numeric array as a BLOB (binary large object).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,284 Views)
please bear my ignorance, can you explain more?
(4,268 Views)
Is this a MySQL forum?  http://forums.mysql.com/
Take some tutorials.
(4,258 Views)
