how to index occurrences in the array
Hi Is there a way how we can index each occurrence in the array?
It seems that search ID Array  is once and I cannot figure out how to do it.
Please advise
Thanks in advance
 Clement
Message 1 of 10
(2,939 Views)
Clement,
Occurrence of what?  If you want to do something with each element of an array, use a for loop with auto-indexing enabled.  You can put Search 1D Array in a loop with the start index connected via a shift register.
Lynn
Message 2 of 10
(2,937 Views)
I tried already but it does not work and I can't figure it out.
It does not work right way
See the pic below. How do we get index for each occreeneces in the array.
Message 3 of 10
(2,933 Views)
Actually,  after I sort ID arr_input. that's how I get result of arr_index
 regards
Clement
Message 4 of 10
(2,932 Views)
Clement,
So you want the index in arr_input of the element with the value 0, then with the value 5, and so on?  Is that what you mean by "occurrence"? Do you want the first "0" or all of them?  Do you need both the value and the index?  How do you want the results displayed?  What is the data represenstation - integer or double?
Lynn
Message 5 of 10
(2,928 Views)
Accepted by topic author astroboy
Do you need only the indexes that matches the search element like this?
Message 6 of 10
(2,921 Views)
Hi P Anand,
 Thanks  which array function do you use. I can't  tell from the look.
I tried every array function but it dies not work. I am using lab v7.1
 Clement
Message 7 of 10
(2,917 Views)
I have used only build array function inside the for loop with a shift register. I treid the same with array functions but it didn't really work. Is that what you wanted to achieve?
Message 8 of 10
(2,915 Views)
Hi Thanks it nearly works but it is better than nothing. at least i know one of the function before proceeding .
regards
Clement
Message 9 of 10
(2,908 Views)
In general you should really be using a Case Structure instead of Select. The only thing harder on your CPU than using Build Array inside a loop is to be doing allocations unnecessarily. With a Case Structure at least you only append to the array when necessary.
Message 10 of 10
(2,902 Views)
