how to implement cluster datatype inside the case structure in LabVIEW
Hii
i have uploaded custom Device in that through RT Driver > Engine> read case > TRUE( RT Read ) > false( sub VI) > Write Variable > writedatatoGlobalvar.VI
IN WritedatatoGlobalVar.vi that Present globalVar(Element)  , Datatype(ELEMENT) & Values to Write (DBL)
so i need  to convert those element from array to Cluster in this VI   Hope You Understand
Siddhu
Message 11 of 15
(718 Views)
Hi siddhu,
I guess you are the same person as here: https://forums.ni.com/t5/LabVIEW/how-to-implement-cluster-datatype-inside-the-case-structure-in/m-p/...
Creating a new thread from a duplicate account for exactly the same problem will not help you more.
You still don't state clearly what you want to do and why.
You must clarify these:
 - "I need to convert those element" -> Which element(s) ?
 - "from array" -> which array? I don't see any relevant array in your code.
 - "to cluster" -> why to a cluster? Where will this cluster be used afterwards?
Also, you may explain it in your native language if that is simpler for you.
Raphaël.
Message 12 of 15
(668 Views)
Hi rapshcul
thank you for the Response
i have answered the question which u have defined
Datatype  , Global Var & value these elements need to convert into cluster by using as array
need to implement those element into cluster and using as array cluster
i need those cluster array to defined those variables datatype in given case structure < Struct unnamed>
Hope U Understand
Message 13 of 15
(596 Views)
Hope U Understand
We are going in circles. I will not continue to respond unless you:
 - Make intelligible english sentences.
 - Explain why you want to do this (without talking about elements, arrays and clusters, be more general).
 - Give more info about where you are stuck exactly in your code (I guess you are stuck somewhere, you don't simply want me to do the job for you, right?)
Raphaël.
Message 14 of 15
(578 Views)
In your Init-VI, do something like this?
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 15
(567 Views)
