how to implement a psophometric filter in Labview software
I am trying to implement a psophometric filter in software for a noise measurment on a telephony system.
(3,998 Views)
Jake8,
I spent some time searching not only ni.com, but many other Web sites as well. I could not find any algorithms to implement. If you have an algorithm, then I may be able to be some help. Are there any other weighted filter you could use instead? Please post again if you have an algorithm.
Randy Hoskin
http://www.ni.com/ask
(3,998 Views)
Hi Jake8,
I don't know about your situation, but my use for a psophometric filter
was to filter the audio before a sinad measurement. I didn't find a filter
algothym in the time domain, but I did find the filter shape in the
frequency domain. My SINAD meter calculates the SINAD from FFT data, so
the all i had to do was apply the filter shape over the FFT data, and so
filtering it, then calculate the SINAD.
It is possible to synthesise a FIR filter from frequency domain data, but
I couldn't make it work. The problem with FIR's, is they do take a lot of
processing compaired to IIR's for the same frequency responce.
If their is an engineer out there that can synthesise a suitable FIR or
IIR filter, I can forward the articles that have the freq responce.
Tim
(3,998 Views)
I can build a psophometric shaped linear phase FIR filter at any desired sample rate. Give me some means to contact you for more information.
(3,998 Views)
