how to implement Transfer Function in Real Time VI?!
Hi all,
I'm relatively new to Labview Real Time modoule and want to implement one Controller in Deterministic Loop! I have already one discrete Transfer Function and searching for the way to build one Controller with it! Is it right to use the Simulation Loop instead of Timed Loop (in this case Deterministic loop) and implement the controller in it?! If it's correct so, should I use the same clock and Priod as Timed Loop?!
It would be very helpful, if there is an Example about using transfer function in Real Time Loops!
thanks for your help,
Mohsen
(2,484 Views)
Hello Mohsen,
I am sorry but I do not really understand what you are trying to achieve. Could you be a little bit more specific on your goals? Which controller are you talking about?
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(2,464 Views)
