how to hold output%3F
hi
i need to hold my output for sometime e.g. 10sec. My output is boolean. I have attached a VI to perceive my problem. When X or Z is true than it has to hold for 10sec. It is not applicable for Y. Please give me an idea how to do that.
Rgrds-
Taslim.
(2,760 Views)
Look at the Elasped Time Express VI.  Feed it with a boolean to reset it.  The output will tell you whether your designated time has passed or not.
(Note:  for your Y boolean, you can simplify that code by using the In Range and Coerce function.)
(2,745 Views)
Thanks Ravens. I tried, but could not be able to develop the algorithm. Would you please give me a quick VI so that I can understand how to use this "Elapsed Time Express VI"? And thanks for the suggestion regarding the simplification of Y. I overlooked that range and coerced function. 🙂
Taslim
(2,739 Views)
Accepted by topic author taslim.reza
Hi taslim,
the attachment shows the quick&dirty solution...
(2,729 Views)
Thanks... It works 😄 :D:
(2,720 Views)
