how to get two 1d array from a 2d array?
Hi, I am new on labview, I am reading data from an arduino thru the serial port. The arduino prints the data in 2 colums, one is the sensor lectures and the second one is the time.
So, I have stored the two colums in a 2d array, where I need to extract them into two 1d arrays each one, because I want to use teh sensor and the time data separately.
Thank you!
(8,408 Views)
Accepted by SercoSteveB
Use index array with one of the indices disconnected. Resize for two outputs.
(depending on which index is disconnected, you either get a row or a column, so just try it)
(8,393 Views)
Thank you so much!
(8,302 Views)
