how to get transfer function back out simulation loop
I'm using the control toolbox and the simulation toolbox on labview 7.1
I use the convert transfer function to simulation block to get the data inside the simulation loop
the problem is that i cannot export the transfer functin data outside the simulation loop.
i can get graph data out using a collector, but not transfer function data
can anyone help please?
an example would be extremely helpful also if possible
cheers
Daniel
(2,776 Views)
Hi Daniel,
It would be great if you could post some code to show the issue, then I can have a look into why you are having trouble getting the transfer function out of the simulation loop.
Lilly
(2,752 Views)
