how to get status of target system battery level
I want to get the current battery percentage on the target system with labview.  Does anyone have DLL that I can use, or can someone please help me.  The target system connected to the Host system running labVIEW via TCP/IP.
thanks,
John
Message 1 of 16
(5,495 Views)
Dear RavensFan,
Thanks for the link, it is a good starts for me, could you show me how I access the windows library kernel32.dll on the target system that connected via TCP/IP from "Call library function node" in labview.
thank you so much.
Jonh
Message 3 of 16
(5,455 Views)
I'm not clear on what is the target system you are referring to.
The VI reads the battery level for whatever PC the VI is running on.
Message 4 of 16
(5,419 Views)
Hi
you will have to run the vi on the target (RT) and then get the values from RT to your PC via TCP/IP.
Regards
Freelance_LV
TestAutomation Consultant
Message 5 of 16
(5,413 Views)
The DLL is Windows only though....
What target are we talking about? Is it a RT Desktop? A Windows Laptop?
Norbert
Norbert
Expert: Geometry
Message 6 of 16
(5,411 Views)
oh yes! the dll is for Windows.
for RT, i remember there were some vis on the RT which gave the memory used and memory free. not remember exactly which one that was.
Regards
Freelance_LV
Message 7 of 16
(5,409 Views)
I'm sorry to confuse everyone here, I'm completely new to the programming.
To make it clear, I have a host system running a LabVIEW and measures the temperature on the target system (laptop).  The question I have, I want to use the LabVIEW to reads the battery percentages on the target system not on the host system, any suggestion/pointer/advice are greately appreciated.
thank you,
John
Message 8 of 16
(5,373 Views)
You need to have the battery check VI run on the laptop.  Then you can pass the information to your host system by way of network shared variables.
Message 9 of 16
(5,362 Views)
Message 10 of 16
(5,362 Views)
