how to get mkv format video in labview
hi all
is there a way to get a *.mkv extension video file in labview?
i know that *.avi video file , by using the vision toolkit , can be used in labview ...but is there a way to do the same thing with a *.mkv file
regards
Regards
Message 1 of 12
(4,801 Views)
You can use ActiveX and a media player application. I have used this method on VLC player, Quicktime, and Windows media player. I can not promise you success but it is worth a try.
Do a search in this forum for more details
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 12
(4,792 Views)
Message 3 of 12
(4,779 Views)
hi thanks for the replies....but my question is still unanswered , what i specifically want to know is that is there anyway i can use *.mkv in the labview and play with the video ......like in the case of *.avi format i can pretty much do anything using the vision toolkit, resize the image , get total number of frames etc etc .... can i do same things to the mkv format video files ??
regards
Regards
Message 4 of 12
(4,746 Views)
people please .....need a little help here ....can labview be used to processes a *.mkv video file ?
Regards
Message 5 of 12
(4,719 Views)
Integrating a media player through ActiveX as already suggested, who understands that format is your best and probably only workable bet.
Message Edited by rolfk on 03-09-2010 11:20 AM
Rolf Kalbermatter  My Blog
Message 6 of 12
(4,702 Views)
USe the vlc player and since vlc plays mkv (I can assure you that) i think it should work.
Message 7 of 12
(4,699 Views)
In a raw video format which I think your are implying by avi by saying that you can get at individual frames then this is fair enough.  However isn't mkv a compressed format i.e a key frame then information regarding how the the next 10/20 frames are processed?  i.e it creates the frames on the fly.  To get at that raw data you would need to convert it to a raw format first.  If you want to just play the file then i would recommend VLC.
Its like the difference between a wav file and an mp3 file.
Craig
LabVIEW 2012
Message 8 of 12
(4,690 Views)
craigc wrote:
In a raw video format which I think your are implying by avi by saying that you can get at individual frames then this is fair enoughHowever isn't mkv a compressed format i.e a key frame then information regarding how the the next 10/20 frames are processedi.e it creates the frames on the flyTo get at that raw data you would need to convert it to a raw format firstIf you want to just play the file then i would recommend VLC.
Craig
Not that it is important. But you are wrongThe mkv file format is a container format. Here is a crash course in the mkv file format
 http://www.matroska.org/technical/whatis/index.html
Message Edited by Coq Rouge on 03-09-2010 01:31 PM
Message 9 of 12
(4,681 Views)
Thanks Rouge,
I knew I was out on a limb on that one 😉
Craig
LabVIEW 2012
Message 10 of 12
(4,675 Views)
