how to get a series of numbers without using a loop?
i want numbers from 0,1,2,3,...........n. how can i obtain this
without using a loop? i tried using the formula node, but it gives
only the last value even though i wrote it using a for stmt. is there
any other way i can get the numbers?
thank you.
Message 1 of 8
(3,631 Views)
You can use the Ramp Pattern signal generation VI.
It is under Analyse>>Signal Processing>>Signal Generation.
Message 2 of 8
(3,631 Views)
You say you don't want to use a ramp but you're trying a for loop in a formula node. That doesn't make much sense. A LabVIEW for loop will execute just as fast if not faster that a for loop in a formula node. You probably didn't create an array in the formula node and update the array but with a LabVIEW for loop it's much simpler. Just wire a control to the for loop's N terminal and wire the iteration terminal out through the for loop and instant array with values 0 to n.
Message 3 of 8
(3,631 Views)
SivaSwetha;
Your requirement of generating numbers without a loop is strange. Is there a reason why you want to generate a sequence of numbers without a loop? My guess is that you are experiencing difficulties using loops, and we can help you if that's the case.
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
Message 4 of 8
(3,631 Views)
the reson for needing a set of numbers is to create a array of boolean
variables to generate a square wave. what i was doing previously was
taking the iteration number from a for loop and divide it by 2. then i
compare the reminder with 0. if it was an even number i would get a
zero and for odd numbers i would get 1. so when i compare i get an
alternative true and false values, which i gave to the digital pins.
but this way i was able to create only a square wave of 1khz. i want
it in the range of some Mhz range.
so i thought the for loop was the one which is running slower and am
trying to replace it.
siva
Enrique wrote in message news:<50650000000500000050D30100-1079395200000@exchange.ni.com>...
> SivaSwetha;
> Regards;
> Enrique Vargas
> www.visecurity.com
Message 5 of 8
(3,631 Views)
The for loop by itself will run very fast (assuming you have no wait statements inside). It is much more likely that it is either a limitation of the hardware you're tying to program or how you're actually doing it. Can you provide more details or post an example of your code?
Message 6 of 8
(3,631 Views)
hi
for sure it is not the limitation of the hardware. i'm using a 6024E
board. and its clock cycle is abt 20Mhz.
i'm not using any sort of delay in the loop. all i'm doing is taking
the iteration number in the for loop and dividing it by 2. the
reminder will be alternative 1 and 0. i compare the reminder with 0
and i get an alternative true or false condition. this i give to a
case structure. wen the condition is true i give out a 1 value to the
digital port and wen it is a false i give out a 0. so in short i get a
square wave. i could read 1khz on the scope.
thank you.
siva.
Dennis Knutson wrote in message news:<506500000005000000B8D30100-1079395200000@exchange.ni.com>...
> your code?
Message 7 of 8
(3,631 Views)
The 6024E is 20 Mhz only for it's counter/timers. The analog output is only 10kS/s and the digital I/O is going to be much slower than that. The digital I/O on this low cost board is static and not designed for high speed operations. If you want a faster square wave, use the timer output or a different board.
Message 8 of 8
(3,631 Views)
