how to get 24-Hour time stamp
We want to write datas with corresponding 24-Hour time stamp to a text file. We are not getting this time format(24-Hour) instead we are getting  12-Hour (AM/PM)only. Can anybody help us towards the same.
Labview Lovers.
(8,987 Views)
If it's windows  ?  You can change this with your 'regional settings' in the control panel. Choose 'customize' and 'time' tab
(8,980 Views)
Since you're saving to a text file, I assume that means you're converting the timestamp to a string. In that case, make sure you're using the right functions - if you use Format Date/Time String you can format the exact structure of your string (including what you want). Look at the help for the function for more details.
___________________
Try to take over the world!
(8,976 Views)
Are you using 'Format Date/Time String' function to botain timestamp from your system??
If you are,  Give format string as "%H:%M" to get 24 hour and minute time stamp
Look at attached VI
regards
Dev
(8,975 Views)
