10-07-2015 04:24 AM
how will i generate continuous sine wave in DAQ 6009? Can any one give me the idea? if any one have the the GL program then please attach. thanks in advance.
10-07-2015 04:55 AM
Hi Ritesh,
there are many examples for doing just that and while I personally never use Express VIs, it's certainly a good point for you to start. Here's a step by step description: http://www.ni.com/pdf/events/us/aowaveform.pdf
10-07-2015 04:57 AM
Hi ritesh,
your DAQ device doesn't support continuous output on it's AO channels - as you have read in the manual (did you?).
You can generate scalar samples in any kind of signal you like and output them at max. 150Hz to those channels…
LabVIEW comes with a lot of example VIs, there are examples on analog output as well.
the GL program
What is a "GL program"?
10-08-2015 02:33 AM
Thanks GerdW
i read that it doesn't support continuous output on it's AO channel, then my question is how would i generate continuous sine wave through daq 6009..u said that LabVIEW comes with a lot of example VIs but where will i get such examples which supports daq 6009..do u have any such example or any link which generates sine wave through daq 6009.
and the GL program is basically i mean to say grapical language(labview example)
Best regards
ritesh
10-08-2015 02:44 AM
thanks PeterFoerster
as i am using daq 6009 and it doesn't support t continuous output on it's AO channel,therefore the pdf link you have given is not suitable for mu daq 6009.
Best Regards
ritesh
10-08-2015 04:29 AM
10-08-2015 08:55 AM
@ritesh312 wrote:
thanks @PeterFoerster
Best Regards
ritesh
Thanks ritesh!
Sorry for trying and failing quite miserably to help you...
10-08-2015 09:06 AM
The PDF file is for the NI USB-6009. It is not suitable for your DAQ 6009 ????
How is that possible?
10-08-2015 12:40 PM
This should work, good enough at low frequencies, as long as LabVIEW operation is not delayed by other programs in the pc
10-09-2015 03:55 AM
are you talking about this pdf http://www.ni.com/pdf/events/us/aowaveform.pdf ??
