how to generate and print 20x20 datamatrix barcode using labview?
Along with the barcode certain datas are to be added to the right of it.
Message 1 of 17
(10,006 Views)
We have previously used Zebra barcode printers - they have some software (Bartender) that allows you to make ActiveX calls to populate a barcode template with data and print it.
(blog)
Message 2 of 17
(9,976 Views)
Which printer are you using ?
Message 3 of 17
(9,976 Views)
You can use an external tool (e.g. Zint Barcode Generator) or an online service (e.g.http://datamatrix.kaywa.com/ ) which can generate a datamatrix picure and load that picture into LabVIEW.
UliB
Message 4 of 17
(9,968 Views)
I use a .NET dll file found at http://www.onbarcode.com/products/net_barcode/.
It is a trial application and occasionally adds the word trial across the barcode.  I get around this by searching for red pixels and if I find one, I just regenerate the barcode until no red pixels found. It's very quick.
aputman
Message 5 of 17
(9,944 Views)
Thanks to your reply. I'm using ZEBRA Zt410 printer.
Message 6 of 17
(9,920 Views)
could any one tell me how to generate a 20x20 data matrix using labview.
Message 7 of 17
(9,891 Views)
Since you started a duplicate thread - I'm going to continue in here.
We have given you a number of different options to generate/print a barcode using LabVIEW.
Do you have the Bartender software installed with the Automation (ActiveX) option? Can you print a label from within the Bartender Software? Do you know how to call ActiveX functions in LabVIEW? For the latter, if you Google 'calling ActiveX LabVIEW' you will get a lot of results. Once you know how to do that, you just need to know which Bartender ActiveX functions to call.
I've attached a couple of screenshots from some quick code my colleague put together before to initialise Bartender, open a label template, fill in a field and print a label. Don't forget the close the references when your application exits. For more information you'll need to read the Bartender documentation.
(blog)
Message 8 of 17
(9,873 Views)
I need to generate data matrix barcode using labview, i dont need to generate a barcode from other application and call that barcode into labview.
i know to call activeX functions.I also used actixeX option (windaq apllication), i have bartender software installed but the thing is that i dont have batender software installed with activeX.
Message 9 of 17
(9,835 Views)
You need to find a VI that someone, somewhere created a means to go from text to the barcode image.  There's a good chance such a VI doesn't exist.
Otherwise you need to figure out the encoding scheme behend this barcode and create a VI yourself that does this.
They are the one 2 things you can do if you don't want to use some external program that is already written to do this.
Message 10 of 17
(9,813 Views)
