04-29-2015 03:57 AM
hi..i want to genarate pwm pulses by using 2 tringle and 1 sine waveform in labview to control 3phase 3level invertr on real time using cDAQmx toolkit. can anyone send mi code or idea how to do it.
04-29-2015 04:17 AM
04-29-2015 04:31 AM
yeah sir i used ,but i dint get what i need..
04-29-2015 04:36 AM
Hi sangeeta,
Then you need to start programming.
Maybe you should read some books too, there are probably papers describing algorithms for your topic.
And NI also offers a tool/toolkit for inverter control…
04-29-2015 05:42 AM
hi
i genarated pwm pulses using sine and tringle, n tried to run on real time using DAQ channel.but when i go to select a DAQ channel there is no browse option .how shoud i select a DAQ channel. i attached my code here.plz help mi.
04-29-2015 05:52 AM
Hi sangeeta,
you never mentioned any "realtime" hardware before! Which one do you use?
On realtime targets (like myRIO, cRIO) you CANNOT use DAQmx functions. There you have to use other ways to access hardware - as is explained in the beginner tutorials and example VIs…
04-29-2015 11:17 PM
m using NI PXIe-1075 as a real time hardware.in that again m using PXIe-6368 for DAQ channels.
04-30-2015 12:19 AM
