how to force numeric control to accept specific values?
hi
How can I force a numeric control to accept specific values ( not a range ) . For example just accept 24 and 28
(2,813 Views)
Set the increment to the difference between the upper limit and the lower limit.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,809 Views)
Hi
use a Ring control instead. define the numbers in the Edit Items property. that would fit your requirement than using a normal numeric control
Regards
Freelance_LV
TestAutomation Consultant
(2,791 Views)
