mjaugustin wrote:
hi
Thanks for your reply,your solution works if only one zero is there if multiple zeros are there how i can find the position of those
As is mentioned above, when comparing numbers that are doubles its best to specify a range. I use an 'Approx Equals' vi that i wrote that you can specify the amount of decimal places the comparison is accurate too.
Have attached the 'Approx Equals' vi in the zip folder if its of any interest to you.
Rgs,
Lucther
Message Edited by Lucither on 04-23-2010 11:22 AM
Message Edited by Lucither on 04-23-2010 11:23 AM
"Everything should be made as simple as possible but no simpler"
