how to find time between triggered signals?
  I'm working on a heart monitor which can measure beats per minute.  I have a good signal (one peak per heart beat).  The problem is I can't figure out how to find the time between peaks.  Any ideas?
Joe
(2,447 Views)
Try Waveform Peak Detection. You can set a threshold and a width. It wil return an an array of locations as DBL. To get the times for each peak, you would simply have to multiply by the dt of the waveform.
(2,440 Views)
