how to find out unuse variables ?
Hello..Anybody
Does anyone know how to find out the unuse variable in Global variable of Labview express 7?
After developing a very big program which consists of lots of variables (all variables are in the same Global-variable file). I want to know which variable that I didn't use it and want to delete from Global file.
Thanks a lot for any kind help!
(2,623 Views)
You've just experienced one of the big problems with using global variables in LabVIEW. If you use global variables you should always try to write accessor functions that read/write that global variable so that you limit access to the global variable. In OO-speak, make the gloabl variable a class. Sort of.
Any way, one way you can do it is to open your top-level VI, then open your global variable. Right-click on the icon pane in the top-right of the global variable's front panel and select "Find all instances". You can then see what part of the global variable is being used. Keep doing this until you've checked off the elements that are being used.
Another way is the brute force method: open your top-level VI and then open your global variable. Then, start deleting elements from the global variable. If the top-level VI breaks, then you know that element is being used. If not, then you know it's not being used.
(2,618 Views)
Thanks a lot....Smiley Very Happy I see the light now
(2,605 Views)
