how to export a continous waveform data from a while loop?
Hello there,
I need to add noise signal to my waveform which is read from a binary file. I use noise generate vi (deleted the density part) from NI example as my sub VI, and put it into a while loop in order to get the continous noise signal, but I don't know how to export this data. There's no waveform come out from the noise waveform output tunnel (on the while loop). I used output tunnel, didn't work, tried shift register, didn't work... Can anybody help?
Also, how to fix the dt problem for the noise generate vi and my original data ( from binarty file)
Thanks in advance!
Wendy
(2,958 Views)
hi
I think notifier can do the trick (an example is shown in the master-slave template).
Another possibility can be a FG (or action engine, look for the nugget ActionEngine, it will change your LV-coding life !)
N
(2,945 Views)
