how to exit from whileloop with Timing Delay
Hello; How to exit from forwhile with timing wait (10s) before finish 10s by stop botem; exemple ; first impulsion to start a while loop with 10 s wait ,before finsh a 10s second impulsion to stop the while loop; in labview 2010 best regrds
Forza Juventus
(3,673 Views)
     Can you explain your question more clearly?And post what all things(VI) you have done so far.Please type all the words completely.
Thanks as kudos only:)
(3,657 Views)
Hello; I want to program a system with a push button 'A' and a LED 1 - If Button 'A' Off, the LED output off 2 - If Button 'A'On the output wait 10s the LED is ON . until now is easy; 3 - while waiting 10s if Button 'A' =off ,directly LED=off at the same time; Thank you,
Forza Juventus
(3,646 Views)
@moussadjenane wrote:
...."forwhile"....
i don't understand...is it a conditional "for" loop or a "while" loop or some other hybrid loop configuration? post your VI!
(3,639 Views)
Forza Juventus
(3,631 Views)
deja vu...
Albert Einstein - "Insanity is doing the same thing, over and over again, but expecting different results."
btw, does this have anything to do with nuclear power?
(3,628 Views)
Show us the code you currently have.  Just repeating your specification word-for-word is not going to help us to understand you problem.
(3,620 Views)
